Role of R-squared
Posted: Sat Oct 16, 2010 9:49 am
by naruto
Hi people, if i set my null hypothesis as h(o):rho=<0 ( no positive serial correlation) and i do a DW (durbin watson) test and get 0.5 which means there is misspec and high serial correlation, basically to reject h(o). Then i do a GLS using AR(1) and got a 1.70 for DW which after referred to the critical d values tells me to not reject the null h(o) and hence, conclude there is no positive serial correlation. Pls advise whether i have interpreted and conclude correctly -
1) The R-squared increased to 0.99 in AR(1) from 0.98 - does this indicates a better fit?
Re: Role of R-squared
Posted: Tue Nov 02, 2010 6:21 pm
by jiya
yes you are correct....but notice that after correction your t-value of coefficients is very low while R-square is quite large, so there is an evidence of multicollinearity. Do a multicollinearity test of your origunal variables before you interpret your findings.
