Compare fixed effect regression coef. across 3 sub-groups
Posted: Sat Oct 09, 2010 2:28 am
As Startz suggested in another post, we can use interactions to test the difference between a coefficient when regression is run across 3 (or more) sub-samples. However, the approach seems problematic when I add fixed effects to the regression.
Specifically, suppose that I have a unbalanced dated panel. The sample is then sub-divided into three sub-samples based on Size (which could have the value of 1, 2 or 3). I want to compare the coefficient on X in the regression: e.ls y c x when the sample is set to Size=1 versus when Size=3.
Using interaction, I run:
smpl @all
equation e.ls y c size=1 size=2 X (size=2)*x (size=3)*x
The last coefficient of equation e above will be numerically identical to the difference between the coefficients on X in equations e1 and e3 below:
smpl @all if size=1
e1.ls y c x
smpl @all if size=3
e3.ls y c x
Everything seems OK so far. But when I want to add the fixed effects into the regression, the problem occurs. Specifically, when I run equation (1) with time and cross-section fixed effects:
smpl @all
equation e_f.ls(cx=f,per=f) y c size=1 size=2 X (size=2)*x (size=3)*x
The last coefficient of equation e_f above is NOT numerically identical to the difference between the coefficients on X in equations e1_f and e3_f below:
smpl @all if size=1
e1_f.ls(cx=f,per=f) y c x
smpl @all if size=3
e3_f.ls(cx=f,per=f) y c x
My question is: with fixed effects, can I still use the interaction to test the difference of a coefficient across sub-samples (as explained ealier, it seems to me that I can't). If not, is there any other way to do so?
Thank you very much for any help.
I use Eviews 6.
Chau
smpl @all
smpl @all if size=1
e1.ls y c x
smpl @all if size=3
e3.ls y c x
smpl @all
smpl @all if size=1
smpl @all if size=3
I use Eviews 6.
Chau
