Comparing T-statistics through a program
Posted: Tue Jan 06, 2009 8:27 am
by VBoykis
Going off of this post:
http://forums.eviews.com/viewtopic.php?f=8&t=244
is there already a way to view t-statistics (or any of the descriptive statistics) of an equation in program/command form?
I want to compare t-statistics of two equations generated by the program, in the same program. Is there a way to do this?
Thank you.
Re: Comparing T-statistics through a program
Posted: Tue Jan 06, 2009 9:08 am
You can use the @tstats data-member of an equation for this. Thus if your equation is called eq1 and you want to retrieve the t-stat of the second coefficient, you would use eq1.@tstats(2)
Posted: Tue Jan 06, 2009 10:07 am
by VBoykis
Thank you. This was extremely helpful.
