ARMA structure for Multivariate GARCH model
DB916
Postby DB916 » Mon Oct 04, 2010 9:20 am
Hi all,
Im using Eviews 6 at the moment and right now i have a series of data. I want to get rid of the autocorrelation by introducing a ARMA structure model. How would I do this? The topic im doing at the moment involves the multivariate GARCH models such as the BEKK model.
Can u give me the instructions to add the ARMA structure on top of the multivariate GARCH?
However if EViews 7 can still do the job. Please give me the instructions anyways.
Thanks heaps! I've been losing a lot of sleep over this!
Re: ARMA structure for Multivariate GARCH model
Postby EViews Gareth » Mon Oct 04, 2010 9:23 am
You can't add MA terms, but you can add AR terms to each equation's specification in your System object. In systems, AR terms are added like so:
y=c(1)*x1+c(2)*x2 +[AR(1)=c(3)]
DB916
Postby DB916 » Mon Oct 04, 2010 9:30 am
Thanks Gareth.
So the command is Object > New Object > System?
Can you explain to me the code that you sent to me please?
How would I say write the code to denote an AR(3) process which was required to get rid of the autocorrelation?
Does Eviews 7 permit MA structure to be introduced into the equation?
thanks heaps again!
Postby EViews Gareth » Mon Oct 04, 2010 10:28 am
You're probably best off reading the manual chapter on Multivariate GARCH.
