hard to reproduce bug
Posted: Tue Sep 21, 2010 4:58 pm
by startz
I had been looking at some stats or a historgram or something in a panel data set, but had closed all windows except the workfile window. I then changed the sample such that all the remaining observations were from a single date and all equaled zero. When I double-clicked on the series I got the "zero variance" alert. After I picked the spreadsheet view everything was okay.
Re: hard to reproduce bug
Posted: Wed Sep 22, 2010 11:23 am
by EViews Pamela
I can't reproduce this ... let me know if you come up with any more info.
Posted: Wed Sep 22, 2010 1:01 pm
by startz
Well, the problem is probably that EViews likes you and doesn't like me. This favoritism has to stop
In fact, I've been able to reproduce it. First I did Histogram and stats. Then I closed the window. Then I reset the sample such that all observations in the sample equalled zero. When I reopen the series window I get the error message.
If you can't make this happen, I can ship you the file. But it's 10 MB.
Posted: Wed Sep 22, 2010 1:46 pm
by EViews Pamela
There are two different ways of getting a histogram in EViews: via the Histogram & Stats menu item, and by selecting the Histogram graph type in the main graph dialog. I was using the latter, which doesn't show the error. However, the first method requires that the variance be non-zero. So, I would suggest using the main graph dialog to get your histogram in this case. (Even though, unfortunately, you won't get the stats.)
