Out of sample forecast with missing values
Posted: Mon Sep 13, 2010 2:21 pm
by PMaier
I'm trying to program out-of-sample forecasts (horizon: 3 years, monthly data) with some of the variables containing missing values (I'd like to simply set the forecasts to NA for these observations). Here's what I have to far:
--- snip
for %j var1 var2 var3
for !loop=1 to 36 step 3
smpl %firstdate %lastdate-36+!loop-1
eq_{%j}.ls ' Equation has been defined prior
smpl %lastdate-36+!loop-1 %lastdate-36+!loop
eq_{%j}.fit temp
series projcurr_{%j} = temp
--- snip
The code works as expected, except for those occasions in which var1-var3 contain missing values. I can set the error count really high, but I'm wondering whether there's a more "elegant" way to test whether a specific observation in a series is an NA. I've experimented with @isna, but that didn't seem to work.
I'm using Eviews 6. Any suggestions would be appreciated.
Many thanks, Philipp
Re: Out of sample forecast with missing values
Posted: Mon Sep 13, 2010 2:29 pm
For a simple case, you could simply set the sample to be the non-NA values:
for %j var1 var2 var3 for !loop=1 to 36 step 3 smpl %firstdate %lastdate-36+!loop-1 eq_{%j}.ls ' Equation has been defined prior smpl %lastdate-36+!loop-1 %lastdate-36+!loop if {%j}<>na eq_{%j}.fit temp series projcurr_{%j} = temp next next
Posted: Tue Sep 14, 2010 7:27 am
by PMaier
Well,
Unfortunately, it doesn't quite work as expected. I had left out a small complication, but as it turns out, the small complication generates an error message.
My smpl if command also tests whether I'm in a specific month (!m can take the values 1-3, depending on the month in the quarter). So my smpl command read as follows:
smpl %lastdate-36+!loop-1 %lastdate-36+!loop if month=!m
Now I've changed as you suggested to:
smpl %lastdate-36+!loop-1 %lastdate-36+!loop if month=!m and {%j}<>na
... and I get the following error:
"Error in sample: Numeric operator applied to string data...."
Strangely enough, each of the conditions in the smpl if command separately works fine, but the combination of the two doesn't.
Any suggestions would be highly appreciated,
Philipp
PS Here's the code again:
eq_{%j}.fit temp
Posted: Tue Sep 14, 2010 8:12 am
I can't replicate that behaviour. In essence I believe you're doing something similar to this:
create m 1990 2010 series month = @month series x=nrnd !m = 3 %j = "x" smpl 1991 1995 if month=!m smpl 1991 1995 if {%j}<>na smpl 1991 1995 if month=!m and {%j}<>na
All three smpl lines run fine for me.
Posted: Tue Sep 14, 2010 9:55 am
by PMaier
Gareth,
Thanks for your help. The last line is exactly what I'm trying to accomplish:
More precisely, I get the following:
Error in sample: Numeric operator applied to string data in "SMPL "2010M6"-36-1 "2010M6"-36-1 IF MONTH=1 AND "AUTO"<>NA".
Quite honestly, the IF statement reads exactly as it should read, so I'm a little confused here. Could it be a bug in the Eviews version I'm using? It the June 19 2007 build.
Thanks again, Philipp
Posted: Tue Sep 14, 2010 10:16 am
That version is massively out of date, so possibly. Try updating.
Posted: Wed Sep 15, 2010 10:34 am
by PMaier
Well,
I did (now I'm running the Jul. 29, 2010 build), but I still get the same error. On a colleague's machine - he has Eviews 7 - I didn't get the error, though.
Has Eviews changed the SMPL IF command? If so, is there any way I can get this to work in Eviews 6 (any workaround)?
Thanks, Philipp
Posted: Wed Sep 15, 2010 10:44 am
Nope, nothing has changed, and my code runs fine for me in my EViews 6.
