Bootstrapping and graphing VAR confidence intervals
Posted: Fri Sep 10, 2010 3:53 am
My aim is to bootstrap (using Eviews 7) and graph impulse responses and confidence bands from a VAR model. Since I would like to use GIRFs instead of SVAR, I have modified the program bqboot.prg to correspond for GIRFs. The modified program appears to work well (would be great if someone could check if the modification yields the desired results, though) up to a three variable VAR. However, when a fourth variable is included in the system, the following error message emerges: "unable to compute due to missing data in "y= @coeff(1)*x1(-1) + @coeff(2)*x2(-1) + @coeff(3)*x3(-1) + @coeff(4)*x4(-1) + @coeff(5)" in "DO_MOD1.SOLVE"." I have been unable to figure out the reason for the error. (bootstrap4.prg)
Moreover, when trying to create the graphs regarding a two or three variable VAR the following error message appears: "SUB_BOOTIRF is not a defined subroutine in "CALL SUB_BOOTIRF(RSP_LVL,LVL_UPP,LVL_LOW,"FIG_LVL")". What could be the problem? (bootstrapbands.prg)
Thank you in advance!
