VEC stability condition check
Posted: Thu Sep 09, 2010 10:25 am
Roots of Characteristic Polynomial
Endogenous variables: LREER11 LPROD RDEBT TBG M1D OPEN LREM
Exogenous variables: C
Lag specification: 1 1
Date: 09/09/10 Time: 12:39
Root Modulus
1.162461 1.162461
-1.060304 1.060304
1.000000 1.000000
1.000000 1.000000
1.000000 1.000000
1.000000 1.000000
1.000000 1.000000
1.000000 1.000000
-0.486868 - 0.074955i 0.492604
-0.486868 + 0.074955i 0.492604
0.208337 0.208337
-0.122074 - 0.132795i 0.180379
-0.122074 + 0.132795i 0.180379
-0.020994 0.020994
VEC specification imposes 6 unit root(s).
Above are the characteristics root from the VECM estimation. There are 7 variables and 33 annual observations. The model has one cointegrating vector and therefore VEC specification shows there are 6 unit roots. Moreover, the model is specified with one lag in difference (which is two lags in level). I have a couple of question on reading the table correctly.
First, are the roots in the table given in the order as it appears in the group window? And, what about the roots of the lags, ie, do the first and second roots represent the two lags of the first variable and subsequently for the other variables?
Second, there are two roots outside the unit circle (on top of 6 unit roots imposed). This means the VECM is not stable, correct? But I wonder why the variables are listed in level when the VECM is estimated in difference? I presume this is so because the error correction part (cointegrated relation) is given in levels. What can done to ensure that the VECM meets stability condition?
Thank you in advance for your help.
anjan
Root Modulus
1.162461 1.162461
-1.060304 1.060304
1.000000 1.000000
1.000000 1.000000
1.000000 1.000000
1.000000 1.000000
1.000000 1.000000
1.000000 1.000000
0.208337 0.208337
-0.020994 0.020994
anjan
