Normtest
Posted: Wed Sep 08, 2010 12:20 pm
by EViews Esther
This thread is about the Normtest add-in that includes many of the dozens of techniques for assessing univariate/multivariate normality.
Re: Normtest
Posted: Tue Sep 13, 2011 8:55 pm
by lucem_fert
Hi!
I'Ve downloaded this Add-in but i don't understand how i can use it. Anyone knows it?
Thanks.
Normtest
Posted: Tue Sep 13, 2011 9:32 pm
I'm sure it has documentation, available from the manage add-ins menu.
Re: Normtest
Posted: Thu Sep 15, 2011 12:41 am
by lucem_fert
Yes you're right!!
It was very very late in the night when i was studyng it!
Re: Normtest
Posted: Mon Jan 09, 2012 1:28 pm
by JamieLevon
I can't access the documentation. Where is the add-ins menu?
Re: Normtest
Posted: Mon Jan 09, 2012 2:23 pm
Between the Options menu and the Window Menu in EViews 7.2.
Re: Normtest
Posted: Sun Apr 22, 2012 1:15 am
by sfarz
I would like to use the normtest in a program,
which are the comand references?
Re: Normtest
Posted: Mon Apr 23, 2012 8:20 am
by EViews Esther
There is no specific section for the command lines, however, each section has the following information:
Add-in Types: Object of interest
Default Proc Name: Command
For example, if you would like to run from the series, you can use the command:
series_name.uninorm
as specified in section UniNorm.
Re: Normtest
Posted: Tue Apr 24, 2012 11:42 am
by sfarz
Thanks a lot!
How can i write a program that performs uninorm for many series and store for each series the results?
Re: Normtest
Posted: Tue Apr 24, 2012 1:32 pm
by EViews Esther
Let me introduce one ad hoc approach. After editing the program, UNIFORM.prg (please see the attachment), you can run the following codes:
group g ser1 ser2 ser3 for !i=1 to g.@count %sername = g.@seriesname(!i) series {%sername} {%sername}.uninorm next next
Please note this is an ad hoc approach.
Re: Normtest
Posted: Wed Apr 25, 2012 3:13 am
by sfarz
thanks again!
Re: Normtest
Posted: Thu Jan 25, 2024 3:29 am
by jmousavi2
hello
I want to store the values ​​"Statistic" and "Prob" of Shapiro-Wilk Test in tow variables (with run Normtest add ins). How should I do this programmatically? thank you
Re: Normtest
Posted: Thu Jan 25, 2024 1:24 pm
by jmousavi2
hello
How can i freeze x.uninorm ?
No matter how hard I try, it doesn't work.
Thank you
Re: Normtest
Posted: Thu Jan 25, 2024 4:13 pm
Probably best off just modifying the source code of the add-in to store whatever you want stored. In effect creating your own version tailored to do what you want it to do.
Re: Normtest
Posted: Fri Jan 26, 2024 3:48 am
by jmousavi2
Thank you very much for your help, problem solved
