Page 1 of 2
X12 Invalid Date Error
Posted: Wed Aug 25, 2010 2:43 pm
by sfawver
I'm trying to seasonally adjust quarterly data 1990q1 - 2010q2 by State and MSA.
My program runs fine until it gets to region 392 and then gives me this error. Also, it doesn't populate the data for region 391. The entire dataset is 35,752 observations. I made a smaller set and then it ran regions>=392.
This is the error I'm getting. I've attached my code and data files. Any help would be appreciated.
Line 3: start = -1.-1
ERROR: Invalid date, expected a monthly abbreviation
ERROR: Expect a date or a list of dates
Line 4: period = 4
ERROR: Assumed seasonal period of 12
ERROR: No time series specified
Re: X12 Invalid Date Error
Posted: Wed Aug 25, 2010 2:57 pm
Might be worth posting a program/workfile that can be run together. Your program requires a csv file that you haven't attached?
Posted: Wed Aug 25, 2010 4:19 pm
by sfawver
Here's the .csv file. I renamed it with the .xls extension in order to upload it.
You'll need to rename it .csv for the program to run. I can't get eviews to read an .xls.
I'm really new to eviews. Thanks for taking a look at it.
Posted: Wed Aug 25, 2010 4:22 pm
Still don't get the same error you're getting.
Posted: Wed Aug 25, 2010 4:31 pm
by sfawver
Were you able to run it on the workfile in the zip file?
The size was 1mb to large to upload so I had to zip it.
It's really weird. If I break the data up into 2 sets it will run all. If all the data is in one workfile and even if I only run the 337 to 436 it stops at 392.
If I run 1 to 436 it also errors out at 392.
Posted: Wed Aug 25, 2010 8:14 pm
Nope
Posted: Thu Aug 26, 2010 7:20 am
by sfawver
What does nope mean?
Posted: Thu Aug 26, 2010 7:58 am
by startz
Just in case, is your copy of EViews uptodate?
Posted: Thu Aug 26, 2010 8:03 am
by sfawver
version 7 Jan 14, 2010 build
i tried to call eviews and even though i have a registered copy i'm not "on the list" of who they will talk to at my company.
my boss tried to call eviews and no one answered the phone.
i can call sas about anything and they fix it pronto.
Posted: Thu Aug 26, 2010 8:14 am
You should probably update your copy.
However until we are able to see exactly what the problem is, I'm not sure how much help we can be.
Posted: Thu Aug 26, 2010 8:56 am
by sfawver
i've updated the software and i still have the same problem.
i was able to shrink the workfile to the upload limit and get eviews to read an .xls. here's the updated program, workfile and .xls.
Posted: Thu Aug 26, 2010 9:09 am
ok, that works, and I get the same error you do. No idea what is causing it yet, but we'll investigate.
Posted: Fri Aug 27, 2010 1:42 pm
The latest patch should fix this for you.
Posted: Fri Aug 27, 2010 1:59 pm
by sfawver
i'm up-to-date and have rebooted my machine, version 7.1 build date Aug 23 2010.
is there a patch for x12 somewhere?
Posted: Fri Aug 27, 2010 2:07 pm
The latest patch is August 27th.
You can either download it manually, or you can have EViews download it itself (Help->EViews Update)
