Hello Folks
Is it possible to fetch files into different pages within a wf using the fetch command or the wfcreat command?
i.e. if i want to fetch daily data and place it in a daily page and then fetch monthly data and place it in a monthly page etc.
many thanks
Wes
Fetch into Different Pages of a WF
Re: Fetch into Different Pages of a WF
When you say fetch, you mean you want to fetch it from a database?
Simply use pagecreate to create the new pages, then pageselect to select which page you're on, then use fetch to fetch the data.
Yes, Gareth - I meant from a database.
Thank you for the heads up on this issue.
Cheers
Wes
Cheers
Wes
If I may please ask one more thing Gareth.
I've been trying to change the labels on the Y-axis - customize them, so that for example I can choose the numbers I want to be shown on the Y-axis. Unfortunately no ammount of pouring over the manuals has yielded anything of significance.
Ideally, if i can change the y-axis values I can also choose the frequency of the tickmarks as well ... so that for example I can have tick marks on the labels i chose and then if required tickmarks in between.
I thank you in advance for any help you may give me on this point.
Wes
Wes
You'll have to be more specific.
Perhaps posting the workfile.
Absolutely ~ please find the attached.
Wes
Wes
- for Gareth.pdf
- (187.98 KiB) Downloaded 527 times
Ah. I don't think that is possible.
appreciate the feedback Gareth ~ kindly let me know if you come across anything that may help in this situation
in the mean time - i'll keep trying on this end and if successful i'll post my findings here in case anyone else needs the same results.
cheers
Wes
cheers
Wes
hello Gareth
this is a follow up our previous discussion regarding customizing the y-axis lables.
reading through the manuals this weekend ~ I discovered the setobslabel command which allowed me to modify the X axis lables (although i haven't mastered the details of this comand yet - but it seems i'm on the right track!)
is there a way to use this command so that it would apply to the y-axis?
Wes
Wes
It is for the X-axis only (well, more correctly, it is for the date/time/id axis)
indeed it is Gareth, however - is there a similar comand for the y-axis?
and if not ~ where can i submit a suggestion so that such a command can be included in a future version / update of e-views?
Wes
Wes
