Data manipulation
y.khairulin
Data manipulation
Postby y.khairulin » Tue Aug 03, 2010 11:27 am
I am new to eviews, so please be patient for my simple and may be obvious questions.
I have data in the following format (see attachment), I imported data in unbalanced/undated format to eviews. As you can see gvkey and year series don't correspond to unique opt_bs observations.
What I need is to generate a new series that will take an arithmetic/weighed average of the observation values corresponding to company specific gvkey and year.
Basically the new series should generate for example: gvkey 001004, year 1997, opt_bs = (1076.006+1452.617)/2.
In other words, there are several option grants to company CEO during the year, but I need an average value of the option grant for a given year, so that later this data can be
structured as dated panel and used in my regression. Thank you in advance for your help.
Book1.xlsx
(8.75 KiB) Downloaded 526 times
Re: Data manipulation
Postby EViews Glenn » Wed Aug 11, 2010 11:14 am
Structure your panel as undated with identifiers GVKEY and YEAR. EViews will create a new crossid variable indexing the different OPT_BS responses. Then @meansby will create a new series with the values you want. Restructure again as desired.
y.khairulin
Postby y.khairulin » Wed Aug 11, 2010 6:19 pm
Thanks a lot, that helped.
