Strings and variables together in the FOR loop?
Posted: Fri Jul 23, 2010 6:47 am
by mr.interested
I wrote a long program performing a number of tests. Previously, I had just a couple of workfiles, so I specified strings/variables at the beginning of the program and changed them each time I ran the program:
%name = "wf1" <-- here !number = 100 <-- here etc. wfopen {%name} [body of the program] save {%name} close {%name}
Now I have dozens of workfiles, and I don't want to retype their names and specific values each time, since I often re-run the program. I also can't have a program for each workfile because I often update the program, and so I have to have only one program. So, my idea was to create the following loop:
%name_1 = "wf1" %name_2 = "wf2" %name_3 = "wf3" !number_1 = 100 !number_2 = 50 !number_3 = 60 etc. for !loop=1 to 3 %name = %name_{!loop} %number = %number_{!loop} etc. wfopen {%name} [body of the program] save {%name} close {%name} next
Logically, each time the loop is run, each string and variable should be updated. For instance, in the first run, %name should take the value of %name_{!loop}, which is %name_1, which is wf1. But that simply doesn't work. The following error occurs:
No workfile exists - Use NEW or OPEN to create or load a workfile in "%NAME" = "wf1"
Why does it not work? I also tried, for example, %name = %name_ + {!loop}, %name = {%name_} + {!loop}, %name = "%name_" + "{!loop}", etc., but none of these worked. The very first one (%name = %name_ + {!loop}) makes sense, and it should work. I also tried to start the loop at the very beginning of the program, but that shouldn't make any difference, and it didn't--it didn't work. What do you think the reason is?
Re: Strings and variables together in the FOR loop?
Posted: Fri Jul 23, 2010 9:02 am
by EViews Glenn
In EViews 7, the following snippet works as expected (or at least as I expected):
%temp = "" %name_1 = "wf1" %name_2 = "wf2" %name_3 = "wf3" for !loop=1 to 3 %name = %name_{!loop} %temp = %temp + " " + %name next statusline {%temp}
and produces
wf1 wf2 wf3
on the statusline.
If you are using EViews 6 or earlier, you are being caught by the fact that we don't allow for recursive substitution (where the substitution variable takes the value of a variable which is itself a substitution variable) in those versions. I don't know a particularly easy way around this.
Having said that, I'm not certain from the description of your problem above why you have the loops in this part of the program. If I'm understanding the nature of the task correctly, you could make a subroutine which did all of your work, given a name and an integer, then have a calling program which specifies values to do the work. Then just include the subroutine in any file that you wish to use (that way you can have a program for each workfile or set of workfiles, but they use the common code).
Or you could upgrade to EViews 7 :wink:
