p-value for t-test
Posted: Fri Jul 23, 2010 5:46 am
by mr.interested
OK, so I encounter the following error when I compute p-value. I calculate it as follows:
'Calculates number of observations: !number = @obs(series1) 'Calculates t-statistic: !t = (@mean(series1)-@mean(series2))/(@stdev(series1)/@sqr({!number})) 'Calculates p-value for t-distribution with N-1 degrees of freedom: '!p = @tdist(!t,({!number}-1))
I compare the values of !t and !p with those from Tests for Descriptive Stats / Simple Hypothesis Tests. While the t-statistic is the same for all series I test, there's a problem with p-value. In same cases the !p returns the correct value, but in some the !p takes a value of, for example, about 8, instead of 0. Is it a bug of EViews or am I doing something wrong?
Re: p-value for t-test
Posted: Fri Jul 23, 2010 9:04 am
I'm afraid that you are going to have to be a lot more specific about what you are doing and what data you are using for us to be able to answer the question.
