VAR vs. System
Posted: Fri Jul 16, 2010 8:20 am
Hello everybody,
I would like to estimate a VAR-Model comprising of two equations.
e.g.:
Var_1=C(1)+C(2)*Var_1(-1)+C(3)*Var_1(-5)+C(4)*Var_2(-1)
Var_2=C(5)+C(6)*Var_2(-1)+C(7)*Var_2(-3)+C(8)*Var_2(-4)+C(9)*Var_1(-1)
When I use the VAR-object I can only use the same amount of lags for each variable. When I use a system-object I can program the equations as described above. Thus, I would like to know, whether I can use a system (based on SUR or FIML estimation methods) to estimate a VAR-model or are there any limitations? After estimating the VAR model I will have to do some forecasting, which should be possible when I transform the system into a model.
Thank you very much and best regards.
Chris
e.g.:
Chris
