Syntax error forecasting Tobit
luiz
Postby luiz » Wed Jul 14, 2010 6:49 pm
I am currently running Eviews 7.1, updated as of July 9.
Eviews is giving a Syntax Error msg any time I try to forecast a censored model with Normal or Logistic Distribution using the forecast button or the command line.
If I try to use the Extreme Value Distribution, the forecast is generated but the results is different from Eviews 6.
In both cases if you look at the representation view, you can see that the formula is wrong.
This problem does not occur in Eviews 6.
Re: Syntax error forecasting Tobit
Postby EViews Glenn » Thu Jul 15, 2010 9:38 am
It's a bug that was introduced recently. I have a candidate fix which has to undergo a bit of testing. With any luck I should have a posting in a couple of days. Sorry about the inconvenience.
If you'd like in the interim, you could send your workfile (support@eviews.com) and I'll estimate your equation with a version prior to the bug.
Our apologies for the inconvenience.
luiz
Postby luiz » Tue Jul 20, 2010 6:25 am
Thank you for the prompt answer and help offer. I stil have access to Eviews 6 so I can run this regression on it until the fix is relelased.
Regards
Postby EViews Glenn » Fri Jul 23, 2010 11:11 am
The fix has been posted.
