For example, in Matlab, you can add "..." (3 dots) to the end of a line and continue to write your command on the next line without breaking the codes.
Can I do something similar in Eviews. This is very useful when, for example, your ls equation is very long.
Thank you
Can I continue a command from a new line?
learneviews
Re: Can I continue a command from a new line?
From the EViews Command and Programming Reference
If you wish to have greater control over the appearance of your lines, you can manually
break long lines using the ENTER key, and then use the underscore continuation character
“_” as the last character on the line to join the multiple lines. For example, the three separate
linesare equivalent to the single lineCode: Select all
equation eq1.ls _ y x c _ ar(1) ar(2)Code: Select all
equation eq1.ls y x c ar(1) ar(2)
Note that the continuation character can be a bit quirky. You always need a space before it, thus it is probably proper to say that the character is \" _\", rather than just \"_. I also find that sometimes it doesn\'t quite accept it unless it also has a space afterwards, so I usually use \" _ \" for continuation.
learneviews
Thank you very much. This is great.
