Error encountered, Help~
Posted: Mon Jul 12, 2010 3:03 am
by nickyclp
I am using eviews 4.1.
I was trying to create a workfile.
the steps were:
File > news > workfile > select undated > set end of observation > ok
File > import > read text-lotus-excel > set order > set upper-left data cell > set excel 5+ sheet name > name for series in number... > ok
My file is here.
fyp.xls
(1.71 MiB) Downloaded 297 times
however, an error message appear:
" invalid cell type found in excel file"
this problem only start occur today. before this it is fine.
is my excel file corrupted?
Thank you. :D
Re: Error encountered, Help~
Posted: Mon Jul 12, 2010 8:59 am
What version of Excel was used to create the file?
Posted: Mon Jul 12, 2010 11:34 pm
by nickyclp
the version of excel i using is excel 2007.
then i convert it to excel 2003. thank.
Posted: Tue Jul 13, 2010 9:22 am
I really can't say what the problem might be. Given that you said that it worked until recently, there does appear to be a problem with the file as EViews 7 only reads the first column.
Posted: Tue Jul 13, 2010 10:57 pm
by nickyclp
so... is it suggested i need to retype all my details in a new excel file?
Posted: Wed Jul 14, 2010 9:36 am
Why not export the data from Excel to text, cleanup if necessary, then re-read into Excel and EViews?
