2-way clustered standard errors
Posted: Fri Apr 30, 2010 8:38 am
I want to calculate clustered standard errors for the coefficients estimated from OLS regression on panel data. Eviews provides the option to calculate the coefficient covariance matrix using White cross section and White period. But the problem is that I want the 2-way clustered standard error, i.e. clustered by BOTH cross section and period (described in page 12 of the attached paper). This is the approach that is currently strongly recommended in research in corporate finance that uses panel data.
I notice that Eviews also has the White Diagonal option to calculate the standard errors. I am not sure if (1) it will give me directly the 2-way clustered standard errors, or (2) it will give the standard error that is robust across theintersectionclusters, or (3) it will give something else. In the words of the paper attached, I am not sure the coefficient covariance matrix Ive got from using the White Diagonal option is (1) the V matrix, or (2) the VI matrix, or (3) something else.
Any help is highly appreciated!
Chau
Chau
