Bootstrap VAR residuals
Posted: Thu Apr 15, 2010 1:38 am
by corrado
Hi everybody.
I am trying to bootsrap VAR residuals in an i.i.d. fashion.
Particularly, I should use this i.i.d. bootstrap of the residuals to generate a given number (say 10.000) of data sets, each of the same lenght as the actual data (after throwing out the first 100 data points to diminish the effect of starting values). For each of the 10.000 samples I have to recalculate the VAR parameters. Then subtract the mean of these estimates from the original parameters to obtain the small sample bias.
For now I have attempted to program the very first part (bootstrapped residuals) as it follows:
'estimate VAR var var1.ls 1 4 y1 y2 y3 y4 y5 @ c 'get residuals to bootstrap var1.makeresid(n=gres) res1 res2 res3 res4 res5 'set monte carlo parameters !reps = 10000 'bootstrap replications 'set random number generator rndseed(type=mt) 1234567 'bootstrap loop for !i=1 to !reps 'bootstrap residuals smpl smpl_est if res1<>na gres.resample y1_a y2_a y3_a y4_a y5_a next
Could anybody help with the last part (or also is there any program already wrritten on this purpose in EViews)?
Any hint will be highly appreciated .
Corrado
