Date axis
Katjes
Date axis
Postby Katjes » Thu Apr 15, 2010 1:16 am
the application: I have calculated the autocorrelation function of two series for lag 1 to 28, saved them in a vector. However, because the graph editor for matrices is not the same as for time series (less possibilities), I converted the vectors back to series, grouped them.
the problem:
I'm not able to manipulate the date axis. So far I reached what I was looking for, but the space between the two digit numbers is too small, hence I would like to show only 1 3 5 .. or any other steps...
Maybe you further know a better way to change the axis to integer numbers instead of date??
Here my code:
smpl 1996Q1 1996Q1+27 ' I reduced the sample size that the vector dimension fits to the sample mtos(AR_EU_n, AAR_EU_n) mtos(AR_EU_t, AAR_EU_t) group AAR_EU AAR_EU_n AAR_EU_t freeze(fig_AR_EU) AAR_EU.line fig_AR_EU.axis(l) font("Arial", 12i) zeroline 'adds the zeroline fig_AR_EU.axis(b) font("Arial", 12) angle(0) 'doesnot turn date fig_AR_{%c}.setobslabel(series) ar_zeit ' AR_ZEIT is a alpha series with the values 1 to 28
Thanks for suggestions,
Katjes
FIG_AR_EU12.pdf
Figure shows the autocorrelation function
(7.3 KiB) Downloaded 517 times
EViews Pamela
Re: Date axis
Postby EViews Pamela » Thu Apr 15, 2010 9:55 am
Use the datelabel command with the interval option. For instance, to label every 5 observations:
fig_AR_EU.datelabel interval(obs, 5)
Pamela
Katjes
Re: Date axis
Postby Katjes » Fri Apr 16, 2010 12:25 am
Thanks Pamela, it works perfectly and looks great!
Gohou
Date Month ) on X axis
Postby Gohou » Tue Apr 20, 2010 4:52 am
hope you are well. I am doing a research and Eviews beginner .. could someone please help me finding how to plot data as month instead of year on my graph?
Regards
Best regards
EViews Pamela
Re: Date axis
Postby EViews Pamela » Tue Apr 20, 2010 9:36 am
Double click the graph to bring up the main graph dialog. In the Axes & Scaling -> Obs/Date axis page, there is a groupbox labeled Date format. Use the drop-down to select the date type you would like.
Pamela
Gohou
Re: Date axis
Postby Gohou » Wed Apr 21, 2010 4:18 am
Thanks a lot Pamela.
Regards
Best regards
