shell not working
Posted: Fri May 08, 2026 10:25 pm
When I enter in the command prompt, I get the following error message:
Perhaps this should be caught by Eviews and given a less opaque error message. But I'm not entirely sure.
shellIt translates to "Fault path name". I think that the error code is ERROR_BAD_PATHNAME. It seems to occur when @datapath refers to a nonexistent folder, which can occur if the folder is deleted outside of Eviews. If this is the case Eviews tries to start the process with a nonexistent working directory.Unable to create process: Katalognamnet är
felaktigt.
