Default Setting for X-Axis Alignment Date?
rinaforristal
Postby rinaforristal » Thu Nov 13, 2025 9:00 am
Hi there,
I'm working with EViews 13 and I'm wondering if its possible to set alignment date to 0 as a default setting. Right now, alignment date = 1, so if my sample starts in 2000, the X-axis shows date labels starting at 2001 and the date axis has to be manually adjusted each time. This is a problem.
Thank you all in advance.
Screenshot 2025-11-13 075111.png (21.25 KiB) Viewed 11488 times
Re: Default Setting for X-Axis Alignment Date?
Postby EViews Gareth » Thu Nov 13, 2025 11:52 am
No, you cannot set the default for that.
