Crash with no warning on stacking operation
Posted: Thu Nov 06, 2025 5:39 am
by yguill1
Using Eviews 14, Apr 8 2025 build.
To reproduce this bug, download the WDI database in CSV format from the World Bank (https://databank.worldbank.org/data/dow ... DI_CSV.zip) and unzip.
Import the database (largest file in the ZIP) into Eviews:
wfopen WDICSV.csv ftype=ascii rectype=crlf skip=0 fieldtype=delimited delim=comma colhead=1 namepos=all eoltype=pad badfield=NA @freq U 1 @smpl @all
Each year appears as a separate series (num2020, etc), so one might want to stack on the time dimension with:
pagestack num? @ *? *
Eviews closes with no error message, no warning.
Re: Crash with no warning on stacking operation
Posted: Wed Nov 12, 2025 9:23 am
Looks like it is an issue with the size of the indicator_name being too long. We'll fix the crash, but in the mean time, if you delete that alpha series before doing the pagestack, you should be good.
Posted: Thu Nov 13, 2025 2:47 am
by yguill1
Thank you for the reply. It's not the first time I see Eviews crash on a pagestack operation and I think you are correct that it is due to one of the series being too long.
Best,
Yvan
