trendtests options not working
ErikG
Postby ErikG » Fri May 09, 2025 3:51 am
Hello and good day to you,
The options for trend test (.trendtests) do not seem to work very well. An output matrix with results is not saved while using the 'out' option. The documentation also seems to be incorrect. Bootstrapped probabilities are still shown even though the 'noboot' option is applied. I've noted that 'bopt=none' is the correct syntax?
WfCreate C:\temp\temp.wf1 m 1990 2020 Series x = @Rnorm x.trendtests(noboot, out=mR) Show mR
Eviews 14 Enterprise edition - April 8 2025 build
Regards,
Erik Glans,
NIER, Sweden.
Re: trendtests options not working
Postby EViews Gareth » Fri May 09, 2025 8:11 am
Yep, will be fixed next patch.
Postby EViews Gareth » Mon May 12, 2025 2:47 pm
Patch is out
