Monte Carlo
jimmy1899
Monte Carlo
Postby jimmy1899 » Mon Apr 12, 2010 1:29 pm
I have had a look at the Monte Carlo examples. I think I will store the simulation results into a matrix.
However I would have liked to learn how to program some kind of recursive algorithm with EViews.
What's a good way to program such a model : Y(t) = a*Y(t-1)+b+nrnd ?
Thanks for you help !
Jimmy
Re: Monte Carlo
Postby EViews Gareth » Mon Apr 12, 2010 1:40 pm
You'll need to seed Y_1 at some value, after that it is relatively simple:
'seed Y_1 smpl @first @first series y = nrnd 'calculate the rest of the values smpl @first+1 @last y = a*y(-1) + b + nrnd
jimmy1899
Re: Monte Carlo
Postby jimmy1899 » Mon Apr 12, 2010 3:00 pm
Thank you very much Gareth
"smpl @first @first" and "smpl @first+1 @last" are delimiters
To set the first element to 5, I could also have written
smpl @first @first series y = 5
This looks pretty easy indeed :mrgreen:
Thanks !
kzmh78
Re: Monte Carlo
Postby kzmh78 » Fri Mar 22, 2013 3:13 am
When monte carlo program generate a sequence of random numbers,
almost of examples had used a Nornal disitrubution,mean is 0, and variance is 1(using command @rnorm or nrnd).
However, I want to use a nornal disitrubution,mean is 2, and variance is 3.
Does EViews have any commands?
Re: Monte Carlo
Postby startz » Fri Mar 22, 2013 6:48 am
2+sqr(3)*nrnd
mvilla29
Re: Monte Carlo
Postby mvilla29 » Thu Apr 11, 2013 12:54 pm
I'm triyin to generate a random number serie, distribited logistic with mean 85.22 and Standard Deviation 18.44, with 260 observations but I don´t know how to do this. I want to to do a Montecarlo experiment with 10.000 iteration like this but I don't know how to do this. Can you help me, please?
Thks!
Re: Monte Carlo
Postby EViews Gareth » Thu Apr 11, 2013 1:07 pm
The @rlogistic function creates random variables from the logistic distribution.
mvilla29
Re: Monte Carlo
Postby mvilla29 » Thu Apr 11, 2013 1:50 pm
Ok, but, how can i asign a mean of 85.22 and a standard deviation of 18.4?
Re: Monte Carlo
Postby EViews Gareth » Thu Apr 11, 2013 2:12 pm
To generate a series with mean X and scale parameter Y, you would do:
series z = x + y*@rlogistic
mvilla29
Re: Monte Carlo
Postby mvilla29 » Thu Apr 11, 2013 2:17 pm
Thank you Gareth!!
Re: Monte Carlo
Postby startz » Thu Apr 11, 2013 2:56 pm
Actually, not quite. The standard deviation of the logistic isn't 1.0. So the scale doesn't give you the standard deviation.
Re: Monte Carlo
Postby EViews Gareth » Thu Apr 11, 2013 2:58 pm
I didn't say anything about std dev. :wink:
Re: Monte Carlo
Postby EViews Gareth » Thu Apr 11, 2013 3:05 pm
A quick bit of Google-fu indicates that to get a mean of m and standard deviation of s, you'd do:
series y = m + s*@sqrt(3/(16*@atan(1)^2))*@rlogistic
