Page 1 of 2
Imporing intraday data from Excel
Posted: Mon Apr 12, 2010 2:39 am
by hendrix
I'm trying to open some intraday futures data into eviews. The data is 5-minute interval with an 45 minute break from 1715-1800.
DATE TIME
01.01.2009 5
01.01.2009 10
01.01.2009 15
01.01.2009 20
01.01.2009 25
01.01.2009 1710
01.01.2009 1715
01.01.2009 1805
01.01.2009 2359
The DATE coloumn is formatted as 'date' and TIME as 'general number' in Excel. I can't get eviews to recognize the format. I have also tried formatting TIME as 'time' with hh:mm as the format. Any ideas of what kind of structure to use when importing?
I'm using Eviews 7.1 and Excel 2010.
Re: Imporing intraday data from Excel
Posted: Mon Apr 12, 2010 7:57 am
Could you post the Excel file?
Posted: Mon Apr 12, 2010 8:36 am
by hendrix
I'm not at my work pc at the moment so i don't have access to the original file, but this is a similar type of structure. Each day contains 279 5-min intervals.
Posted: Mon Apr 12, 2010 10:50 am
The problem you're going to have is with the "23:59" end point of the day. EViews will believe you have minute-by-minute data, with lots of missing observations (i.e. 01,02,03,04,06,07,08 etc...). What you really want is EViews to believe you have 5 minutely data, but it will never believe that as long as you have that "23:59".
Apart from that though, you can create a valid date/time series with the following command:
series datetime = date + @makedate(@floor(time/100), @mod(time,100),"hhmi")
Posted: Mon Apr 12, 2010 11:02 am
by hendrix
Okei, thank you. I will try some sort of workaround for the 23:59 interval. Maybe if I do a find and replace of all the 2359 values to just 0 in Excel before the import. Will eviews then understand that 0 refers to 00:00?
Posted: Mon Apr 12, 2010 11:05 am
It won't automatically pick up the structure, but in two lines you can get EViews happy:
pagestruct @date(datetime)
Posted: Mon Apr 12, 2010 11:09 am
by hendrix
Thank you! I will try this tomorrow and report back
Posted: Wed Apr 14, 2010 4:53 am
by hendrix
Works perfect Gareth, one more question:
"smpl 1/28/2009 3/18/2009" returns observations for 1/28/2009 thorugh 3/18/2009. Is it possible to create a sample containing only spesific dates? "smpl if @date= 1/28/2009 and @date=3/18/2009" seems logical but doesn't work. I need it to create dummies on the spesific dates.
Posted: Wed Apr 14, 2010 7:19 am
Smpl 1/28/2009 1/28/2009 3/10/2009 3/10/2009
Or something similar
Posted: Wed Apr 14, 2010 10:54 am
by hendrix
Of course
Posted: Fri Apr 30, 2010 5:39 am
by hendrix
What if I want to sample all except specific dates? I have around 100 days I want to exclude from the sample.
Posted: Fri Apr 30, 2010 7:25 am
by tchaithonov
Just create a dummy variable indicating which obs you need, and then smpl @all if varx = 1.
Posted: Fri Apr 30, 2010 8:09 am
Tchaithonov's suggestion is a good one. You can also use @date, along the lines of:
smpl if @date<@dateval("2009/10/03") and @date>@dateval("2009/11/03")
which would exclude all dates between 3rd October 2009 and 3rd November 2009.
Posted: Fri Apr 30, 2010 8:16 am
by hendrix
Thanx, works perfect.
Posted: Tue May 11, 2010 4:37 am
by hendrix
Hi again,
Do you have a similar command to get eviews to recognize 1 minute data (see att.)?
