Identical Higher, Lower bounds and mean in Stochastic Model
Posted: Wed Oct 30, 2024 3:07 am
Hi everyone,
I’m encountering an unusual issue while running a stochastic model in EViews. Out of a system of 62 equations, nearly all variables produce bounds as expected, with higher and lower bounds differing from the mean. However, for one specific variable, "solve solution" returns identical values (or values that closely overlap) for higher, lower, and mean.
This behavior seems strange, especially given that for all other variables the code works well.
Additionally, I verified that standard deviations are very close to zero and this would imply that the variance is close to zero as well, which could explain why the bounds appear identical to the mean. But I do not understand the reason behind it also considering that settings for this variable are the same as those for other variables in the model.
Has anyone experienced a similar issue or have any suggestions ?
Thanks so much for any insights!
