While there isn't an EViews command to automatically open a snapshot, you can do it programmatically.
First, EViews snapshots are usually saved in the same folder as the base workfile/program. The folder is hidden and the folder name just starts with the name of the base file followed by "_Snapshots". For example, if you have a workfile named "simple.wf1", the snapshot folder name would be "simple.wf1_Snapshots".
Next, the snapshots in that folder are just copies of the original workfile/program. The only difference is that each snapshot is prefixed with "snapshot_" (instead of the original base name) followed by the current date and time (local). There's also a matching JSON text file for each snapshot that contains some metadata. For our "simple.wf1" example, you might see:
- snapshot_20260725_180156.json
- snapshot_20260725_180156.wf1
Because snapshot_20260725_180156.wf1 file is just a regular workfile, you can open this using our WFOPEN command. You just have to figure out the path.
Here's an example EViews Program that does this for a given folder and workfile name:
' Find the most recent .wf1 file in "<StaticName>_Snapshots"
'--- 1. Inputs: set these as needed -------------------------------
%basepath = "C:\files\" ' folder that CONTAINS the snapshots folder
%staticname = "simple.wf1" ' your static file name (no extension needed)
'--- 2. Build the snapshots subdirectory path ---------------------
%subdir = %staticname + "_Snapshots"
%snapdir = %basepath + %subdir
'--- 3. Make sure the folder actually exists -----------------------
if @folderexist(%snapdir) = 0 then
statusline Folder not found: {%snapdir}
stop
endif
'--- 4. Get the list of ALL files in that folder --------------------
%filelist = @wdir(%snapdir, "f")
!nfiles = @wcount(%filelist)
if !nfiles = 0 then
statusline No files found in {%snapdir}
stop
endif
'--- 5. Walk the list, keeping only .wf1 files, track the "largest" name
%latest = ""
!found = 0
for !i = 1 to !nfiles
%candidate = @word(%filelist, !i)
%ext = @lower(@right(%candidate, 4)) ' last 4 chars, e.g. ".wf1"
if %ext = ".wf1" then
!found = 1
if %latest = "" then
%latest = %candidate
else
if %candidate > %latest then
endif
endif
endif
if !found = 0 then
statusline No .wf1 files found in {%snapdir}
stop
endif
'--- 6. Report / use the result -------------------------------------
%latestpath = %snapdir + "\" + %latest
'statusline Most recent .wf1 snapshot: {%latest}
'statusline Full path: {%latestpath}
' Example of using it:
wfopen {%latestpath}
