@recode one series with another if X is greater than Y
Posted: Wed Jun 12, 2024 9:26 am
by bpuffer
Hi!
I am attempting to replace observations from one series with another. So, if and observation for X > Y, make X = Y. However, the following code is throwing an error:
%ne = "CT MA ME NH NJ NY PA RI VT"
%nc = "IA IL IN KS MI MN MO ND NE OH SD WI"
%so = "AL AR DC DE FL GA KY LA MD MS NC OK SC TN TX VA WV"
%wt = "AK AZ CA CO HI ID MT NM NV OR UT WA WY"
for %r NE NC SO WT
for %s {%{%r}}
%tf = BPPRIV_S{%s}
%sf = BP1FH_S{%s}
{%sf} = @recode({%sf} > {%tf}, {%tf}, {%sf})
The error is Series assigned to string in "%TF = BPPRIV_SCT" on line 42. Line 42 is the recode line.
Any help would be greatly appreciated!
Re: @recode one series with another if X is greater than Y
Posted: Wed Jun 12, 2024 9:35 am
Are these bits correct:
%tf = BPPRIV_S{%s}
%sf = BP1FH_S{%s}
Its hard to judge what's going on without knowing what the various objects are.
Posted: Wed Jun 12, 2024 9:59 am
by bpuffer
I believe so, yes. Here's the entire code up to that point. It will run through everything just fine up until the recode line.
'REGION & DISTRICT DEFINITIONS
'NE
%d1 = "CT MA ME NH RI VT"
%d2 = "NJ NY PA"
'NC
%d3 = "IL IN MI OH WI"
%d4 = "IA KS MN MO ND NE SD"
'SO
%d5 = "DC DE FL GA MD NC SC VA WV"
%d6 = "AL KY MS TN"
%d7 = "AR LA OK TX"
'WT
%d8 = "AZ CO ID MT NM NV UT WY"
%d9 = "AK CA HI OR WA"
pageselect M
for %f %s ??BPPRIV BPPRIVNS_S?? ??BP1FH BP1FHNS_S?? 'HOUSTNENSA HSNS_NE HOUSTNE HS_NE HOUSTMWNSA HSNS_NC HOUSTMW HS_NC HOUSTSNSA HSNS_SO HOUSTS HS_SO HOUSTWNSA HSNS_WT HOUSTW HS_WT HOUSTNE1FNSA HONS_NE HOUSTNE1F HO_NE HOUSTMW1FNSA HONS_NC HOUSTMW1F HO_NC HOUSTS1FNSA HONS_SO HOUSTS1F HO_SO HOUSTW1FNSA HONS_WT HOUSTW1F HO_WT
copy(o) FRED::{%f} {%s}
for %c BP1FH BPPRIV
{%c}NS_SDC.ipolate {%c}NS_SDC_I
series {%c}NS_SDC = {%c}NS_SDC_I
delete {%c}NS_SDC_I
for %r NE NC SO WT
for %s {%{%r}}
{%c}NS_S{%s}.x13 @arima @seats
series {%c}_S{%s} = {%c}NS_S{%s}_S11
delete {%c}NS_S{%s}_S11
for %r NE NC SO WT
for %s {%{%r}}
%tf = BPPRIV_S{%s}
%sf = BP1FH_S{%s}
Posted: Wed Jun 12, 2024 10:04 am
It looks like BPPRIV_S{%s} is a series? So you're setting a string equal to a series?
Posted: Wed Jun 12, 2024 12:00 pm
by bpuffer
I am trying to set a series equal to a series, but only for the observations that meet the qualifications. So, in months where BP1FH_S{%s} > BPPRIV_S{%s} make BP1FH_S{%s} in those months equal to BPPRIV_S{%s}.
Posted: Wed Jun 12, 2024 1:16 pm
Then you will need to change the lines:
%tf = BPPRIV_S{%s}
%sf = BP1FH_S{%s}
Perhaps something like:
%tf = BPPRIV_S{%s}.@name
%sf = BP1FH_S{%s}.@name
Posted: Thu Jun 13, 2024 12:50 pm
by bpuffer
That worked. Thank you.
