Saving break years after structural break test
Posted: Thu May 30, 2024 7:56 am
by pras
Hello everyone,
I am very new with EViews. Can you help me how to save the years from the structural break test? Here is my simple code and attached is the sample data. The output that I aim is dummy variable for the years when structural break take place for each country/variable. Thank you.
%country = "BGD IND LKA MDV PAK"
' Loop through each dependent variable and run the regression
for %y {%country}
' Create an equation object with a dynamic name
equation eq_{%y}
' Estimate the regression
eq_{%y}.ls {%y} c year
' Run multibreak test
eq_{%y}.multibreak c year
Best regards,
Pras
Re: Saving break years after structural break test
Posted: Thu May 30, 2024 8:06 am
You could estimate via breakls instead of using the breaktest, and then store the break points.
for %y {%country}
equation eq_{%y}.breakls {%y} c year
string {%y}_breaks = eq_{%y}.@breaks
Posted: Thu May 30, 2024 9:56 am
by pras
Hello Gareth,
Thank you your help. Is there any way I can export the string into excel? Ideally I need to have an excel table where the rows are the year and the columns are each country/variable, with value = 1 if the year is equal to the break year. If that is not possible with EViews, at least I need to combine all the resulting string into one group and then export them to excel. At the moment, I am manually adding the break year dummy in excel, but it's time consuming and error-prone. Sorry if my question is too basic. Thank you.
Posted: Thu May 30, 2024 11:36 am
You can make a table object, insert the information you want into the table object, then save the table to disk as an Excel file, or csv.
Posted: Thu May 30, 2024 12:36 pm
by pras
Thanks, Gareth.
Do I have to fill the table manually as in my simple code below, or is there any way to automate which rows to be changed based on the structural break years? For the way I did it below, it's still time consuming and error-prone. Thanks.
' Creating the table
' Step 1: Define the number of years
scalar startYear = 1990
scalar endYear = 2022
scalar numYears = endYear - startYear + 1
' Step 2: Create a table with the appropriate number of rows and 6 columns
table (numYears + 1, 6) mytable ' +1 for the header row
' Step 3: Name the columns
mytable(1, 1) = "index"
mytable(1, 2) = "year"
mytable(1, 3) = "BGD"
mytable(1, 4) = "IND"
mytable(1, 5) = "LKA"
mytable(1, 6) = "MDV"
mytable(1, 7) = "PAK"
' Step 4: Fill the "Year" column with the range of years
for !i = 1 to numYears
mytable(!i + 1, 1) = !i ' Fill the index column
mytable(!i + 1, 2) = startYear + !i - 1 ' Fill the year column
' Filling the break years dummy for BGD
mytable(13, 3) = "1"
mytable(20, 3) = "1"
mytable(24, 3) = "1"
mytable(28, 3) = "1"
Posted: Thu May 30, 2024 12:51 pm
Entirely depends on what you want it to look like in Excel. But the simplest is probably something like:
table mytable
!row = 2
for %y {%country}
%breaks = eq_{%y}.@breaks
mytable(!row,1) = %y
!col = 2
for %j {%breaks}
mytable(!row, !col) = %j
!col = !col+1
!row=!row+1
Posted: Thu May 30, 2024 3:33 pm
by pras
Thanks a lot, Gareth.
If there are no break years, the code returns an error. I think I need to modify this code:
!col = 2
for %j {%breaks}
!col = !col+1
I tried the following, but still returning error. Could you please help, Gareth? Thanks a lot!
!col = 2
if {%breaks} <> "" then
for %j {%breaks}
!col = !col+1
else
mytable(!row, !col) = ""
endif
Posted: Thu May 30, 2024 3:43 pm
by pras
Hello Gareth,
I think I found the solution as follows. Thanks for your help.
!col = 2
if @len(%breaks) > 0 then
for %j {%breaks}
!col = !col+1
else
mytable(!row, !col) = "" ' Fill empty cells in case of no breaks
endif
