Passing Variable to "R"
Posted: Mon Mar 25, 2024 10:54 am
by kcaron
I'm trying to use EViews with R.
My program begins in EViews and asks the user for some information:
- series to forecast in R, called %fcst_series
- start year for forecast, called !start_year
- start month for forecast, called !start_month
- frequency of data, called !frequency
My code then tries to feed these variables into the R code starting with:
xon
fcst_series <- ts({%fcst_series}, start = c({!start_year},{!start_month}), frequency = {!frequency})
However, R doesn't like {%fcst_series} formatting. It appears to reject the "{}" and the "%"...
I can't figure out what the right way is to transfer this information to R.
Any ideas would be greatly appreciated!
Many thanks,
KC
Re: Passing Variable to "R"
Posted: Mon Mar 25, 2024 10:57 am
Presumably you've already used XPUT to transfer the data across, and the issue is referencing that variable in R?
Posted: Mon Mar 25, 2024 10:58 am
by kcaron
Correct...
I had no issue moving the data to R... Just how to get the variables across into R.
Posted: Mon Mar 25, 2024 11:19 am
If you have something like:
%fcast_series = "X" xput {%fcast_series} xon fcst_series<-ts({%fcst_series}) xoff
that will be passed into R as:
fcast_series<-ts("x")
which will cause the error because R is not expecting the quotes. So you'd need to use R to remove the quotes.
Perhaps an easier way is to do this:
%fcast_series = "X" xput(name=foo) {%fcast_series} xon fcst_series<-ts(foo) xoff
Posted: Mon Mar 25, 2024 11:32 am
by kcaron
I appreciate that. But what about passing a parameter like "frequency", for example?
Posted: Mon Mar 25, 2024 1:52 pm
Don't put it in braces.
