Hi Gareth,
I would like to inquire if there is an add-in or command available for conducting forecasts using estimates from a Switching VAR model (MSVAR). Your guidance on this matter would be greatly appreciated.
Kind regards,
Nwabisa Ndzama
estimating the the BTVC-VAR model.
Re: estimating the the BTVC-VAR model.
Hi Gareth,
This syntax didn't work:
ca_{%c}_var06.forecast(f=na) NNS
'Error message: Forecasting is not available for this VAR estimation method in "CA_{%C}_VAR06.FORECAST(F=NA) NNS" on line 1913.
Kind regards,
Nwabisa Ndzama
Kind regards,
Nwabisa Ndzama
Hi Gareth,
With Eviews 14 I was able to successfully estimate the BTVC-VAR model.
Thanks,
Nwabisa Ndzama
Thanks,
Nwabisa Ndzama
Hi Gareth,
Thanks,
Nwabisa Ndzama
Thanks,
Nwabisa Ndzama
Hi Gareth,
Thanks,
Nwabisa Ndzama
Thanks,
Nwabisa Ndzama
Hi Gareth,
I trust you are well.
I have tried to estimate the STVAR, using both the Maximum Likelihood Estimation and the NonLinear Least Squares (nls). I get an error message. Please see attached files.
Kindly assist,
Nwabisa Ndzama
Kindly assist,
Nwabisa Ndzama
- Screenshot 2024-10-13 150707.png (254.76 KiB) Viewed 1135 times
- stvar_model_nwabisa_ndzama.prg
- (10.06 KiB) Downloaded 125 times
