Exec and directory
Posted: Tue Dec 19, 2023 11:39 am
by Sharky
This is very strange and I can't see what I'm doing wrong.
The code
cd "<...>\PhD version files"
<various minor routines>
exec ".\create all appex v5.prg"
When I run it, I get an error saying that the program 'create all appex v5.prg' isn't found on disk in a totally different place!
<...>DOCUMENTS\EVIEWS ADDINS\CREATE ALL APPEX V5.PRG not found on disk in "EXEC ".\CREATE ALL APPEX V5.PRG"" on line 35.
I reset with cd directly and try running that line but each time it thinks I'm trying to call a program from an 'eviews addins' folder for some reason.
The status line has the correct Path.
I'm running Eviews 12 University Edition
Re: Exec and directory
Posted: Tue Dec 19, 2023 11:55 am
Posted: Wed Dec 20, 2023 2:34 am
by Sharky
Thanks Gareth. Any idea why it's calling from addins even though I'm using
Posted: Wed Dec 20, 2023 8:16 am
Is the program you are running from saved to disk?
Posted: Wed Dec 20, 2023 8:39 am
by Sharky
Yes, saved to and running from C drive.
Posted: Wed Dec 20, 2023 8:57 am
Is your copy of EViews up to date?
Posted: Wed Dec 20, 2023 10:05 am
by Sharky
I downloaded Eviews 12 University edition about a month ago - is that up to date?
Posted: Wed Dec 20, 2023 10:34 am
Should be.
Seems strange.
Can you do the following:
- Create a brand new program.
- Enter a single line:
- Save as "c:\temp\test.prg" (make sure you have a folder called test)
- Run
It should error saying "c:\temp\foo.prg not found"
Posted: Wed Dec 20, 2023 12:38 pm
by Sharky
Should be.
Seems strange.
- Run
Not sure what you mean by 'a folder called test' but I saved in both the location specified and a subfolder called 'test'. In both cases I got the error:
C:\TEMP\TEST\FOO.PRG not found on disk in "EXEC ".\FOO.PRG"" on line 1.
C:\TEMP\FOO.PRG not found on disk in "EXEC ".\FOO.PRG"" on line 1.
Posted: Wed Dec 20, 2023 12:40 pm
ok, so that appears to be working correctly. Something specific about your program is causing the weird behaviour.
(and I mean to say a folder called "temp". My bad)
Posted: Thu Dec 21, 2023 6:56 am
by Sharky
OK I've replaced with include and for some reason it works. Very strange.
