SRVAR & EViews 13
Posted: Sun Jun 25, 2023 1:57 pm
by fmramos
Hi everyone!
Have any of you tried the add-in srvar in EV13? I'm getting the "Error 247 in the encrypted program" even with .prg examples. My EV13 build is the Jun 14, 2023, enterprise edition. Meanwhile, coming back to struggle with R packages... :-(
Any help is highly appreciated!
Re: SRVAR & EViews 13
Posted: Tue Jun 27, 2023 4:43 pm
by dakila
Yes, I will try to update it soon for Eviews 13.
Posted: Thu Jun 29, 2023 11:12 am
by fmramos
:P Cool!!!
Posted: Thu Jun 29, 2023 11:04 pm
by dakila
Done.
Posted: Wed Jul 05, 2023 6:29 am
by fmramos
Great to see it updated. The examples run nicely in both EV12 (my work) and in EV13 (personal PC). However, I can smoothly only the two examples you give (based on Uhlig seminal paper, based on both penalties/draws). For my personal data (Brazil REER, financial and macro variables), I can run only if files are stored inside the Add-in directory and it runs intermittently. Sometimes, with a EViews clean window it runs. But usually, the same message of 'encrypted program'. Anyway, tks. I was already able under some circumstances to not use the R library for this. ;-)
Posted: Wed Jul 05, 2023 6:41 am
by fmramos
A post-script... Apparently I can run anything if I estimate through .prg. It goes bad if I try to use command prompt and/or visual buttons/commands.
Posted: Thu Jul 06, 2023 8:03 pm
by dakila
I will try to fix it soon.
Posted: Thu Jul 06, 2023 8:16 pm
by dakila
If you use the dialog box (menu) you don't need to create the restriction vector, just put the sign index. For example, just insert +4, -2, -3, -5 in the sign restriction vector box.
