EVIEWS 13 crashes on printing spool in pdf
Posted: Thu Jun 01, 2023 2:17 am
Dear Support,
When I print a large spool into a PDF in Eviews 13 it crashes (using microsoft to PDF). When I use Eviews 12 it prints the same spool without objection. I managed to reproduce the error on another PC with Eviews 13. I use the microsoft to PDF as it can scale the size of the spool. If i use the "save spool to disk" command, I succeed to save the pdf but the format is not adjusted to the page size.
The spool in question is quite big and contains several large tables and hunderts of graphs.
Kind regards,
Michel Geller
Kind regards,
Michel Geller
