Graph settings disappear from updateable graphs in panels
mamo
Postby mamo » Wed May 17, 2023 2:47 am
Dear Eviews team,
I use Eviews 13 Oct 2022 build.
Changes to graph atributes in a panel updateable graph seem to disappear unexpectedly once the graph is updated. The code below provides an example with respect to a text which is added to a panel graph. The added text would disappear once the graph is updated. The same happens to changes of other attributes, such as, for instance, the scaling of the left axis, which would also disappear after updating the chart.
'Create a panel file wfcreate a 2000 2010 2 series x=nrnd 'create a panel graph freeze(gra) x.line(panel=i) show gra 'Add some text to the graph gra.addtext(t) "Deviation of storks" 'Make the graph updateable gra.setupdate(m) 'Change the workfile sample smpl 2002 2010 'Update the graph to align it to the changed wf sample gra.update 'The text which has been added above disappears
