@right error
BT454
@right error
Postby BT454 » Thu Feb 09, 2023 8:41 am
Good morning!
I'm trying to determine capture the right most character from a temporary string, that is a list of the members of a group. However, the code either crashes with a syntax error if I put brackets around the code name as below
group g_max hsddcus_* %max = g_max.@members %max = @replace(%max,"_"," ") %test = @right({%max},1)
or returns nothing, if I do not use brackets, as below
group g_max hsddcus_* %max = g_max.@members %max = @replace(%max,"_"," ") %test = @right(%max,1)
Any thoughts on what I'm doing wrong?
As always thank you very much! The fantastic help and customer support is greatly appreciated!
Bob
Re: @right error
Postby EViews Gareth » Thu Feb 09, 2023 8:59 am
The @right function requires the first argument to be a string, so using {%max} is wrong.
The second syntax (without the {}) is correct.
The reason that you end up with an empty string is that the last character of %max is a space. If you add an @trim to the program it should work.
group g_max hsddcus_* %max = g_max.@members %max = @replace(%max,"_"," ") %max = @trim(%max) %test = @right(%max,1)
BT454
Re: @right error
Postby BT454 » Thu Feb 09, 2023 9:16 am
Thank you sir!
