How do I configure a user's settings/.ini-file?
Posted: Fri Jan 27, 2023 4:52 am
It would be advantageous for us to configure some of our user's settings to be the same, such that graphs looks identical and such that users don't leave a ~RG-file every time they do minor changes in a program.
I see there are some .ini-files, and I assume I will have to make a program that modifies/overwrites the user's file. How do I retreive the path of the ini-file folder for each user?
And any tips on how to modify the ini-files? Does each setting need to be in the order they originally are in and modified in place, or can I append the new settings at the end of the ini-file and the settings will update? How do I modify the graph-settings?
If modifying the files is not the way to go, how would I otherwise solve this?
