Different R squared value
Posted: Sat Jan 21, 2023 10:26 am
by Khawla
I have applied the command ls y c x ar(1) using Eviews, and I applied the cochrane orcutt function using R package and excel.
I got the same results for all the statistics in all these applications, accept the value of R squared, where it is different in Eviews. I have attached the results.
Could you please help me to know why, especially, the difference is large.
Re: Different R squared value
Posted: Sat Jan 21, 2023 6:14 pm
I don't see the AR results in your R output.
Posted: Sun Jan 22, 2023 8:33 am
by startz
What command did you use in R? I don't think
lm()
does Cochrane-Orcutt, does it?
(By the way, I'd be willing to wager that the R-squared shown in the R output is from the quasi-differenced variables.)
Posted: Sun Jan 22, 2023 9:50 am
by Khawla
Hi, I appreciate your quick response, thank you.
I used the function cochrane.orcutt (lm function) from the packages("orcutt"). This R function directly presents the new results of the Regression analysis using the transformed data (transformed using AR(1)) which what I had attached.
Regards,
Khawla
Posted: Sun Jan 22, 2023 9:58 am
by Khawla
lm()
I used the function cochrane.orcutt (lm function) from the packages("orcutt"). I first applied (lm) function and then cochrane.orcutt (lm function).
Posted: Sun Jan 22, 2023 12:26 pm
by startz
The Cochrane-Orcutt package is returning the R-squared on the quasi-differenced model. This is a bug. EViews has it right.
(Orcutt would not have been pleased.)
Posted: Sun Jan 22, 2023 3:06 pm
by Khawla
[quote="startz"]The Cochrane-Orcutt package is returning the R-squared on the quasi-differenced model. This is a bug. EViews has it right.
(Orcutt would not have been pleased.)[/]
Thanks for your response, it was very helpful.
Best wishes,
Khawla
Posted: Tue Jan 24, 2023 11:59 am
by Khawla
Hi and sorry to bother you again.
I just wonder, with regard to the use of Cochrane-Orcutt procedure and as much as I understand that if the all the dependent and the independent variables are transformed using rho, then thevalues of the predicted, residuals, and all the statistics including R squared value will be based on these inputs and be of the same form, but you said that quasi-differenced model is not be used in Eviews. My question is how the results of predicted, residuals, R squared values are obtained in Eviews if it does not depend on quasi-differenced.
regards
Posted: Tue Jan 24, 2023 12:08 pm
by startz
EViews doesn't exactly do Cochrane-Orcutt. By default estimation is by maximum-likelihood. The difference is likely to be very small.
Posted: Tue Jan 24, 2023 1:02 pm
by Khawla
I really appreciate your help. I would be grateful if you recommend a source.
Best Wishes
Posted: Tue Jan 24, 2023 1:06 pm
by startz
The EViews help system describes the alternatives available in EViews quite extensively.
Posted: Wed Jan 25, 2023 9:42 am
by Khawla
Thank you very much.
Regards
