sample issue
Posted: Wed Apr 07, 2010 11:05 am
by mark
I have a excel series with 22,000 observations using the following format 2006-04-20
I have imported the series into eviews using numeric display "Period" a date format of "YYYY:MM"
I want to sample by year (6 years of observations), however when I input the sample code, it get's rejected everytime.
Any advice would be appreciated.
thanks
Re: sample issue
Posted: Wed Apr 07, 2010 11:13 am
Could you provide more details?
What sample code do you input, and how does it get rejected?
Re: sample issue
Posted: Wed Apr 07, 2010 12:32 pm
by mark
series name is "date"
using the sample menu:
@all
date ="2006:01" "2009:04"
Error message reads "error in sample: 2006:04 is not defined"
Re: sample issue
Posted: Wed Apr 07, 2010 12:40 pm
by mark
Using the sample window
@all
year= 2005:04 2008:01
error in sample: 2005:04 is not defined
here is an extract of the raw data:
2005:04
2005:04
2005:04
Re: sample issue
Assuming your workfile is dated, you probably just need to type "2006:01 2009:04" in the top box of the sample dialog, and leave the bottom part blank.
If you really want to use the date series, then you would fill this in the bottom box:
date >= @dateval("2006:01) and date <= @dateval("2009:04")
Re: sample issue
Posted: Wed Apr 07, 2010 1:43 pm
by mark
Hi - tried your solution to no avail
I've attached the workfile in an unstructed format along with the sample declaration. Hope you can help
Re: sample issue
Posted: Wed Apr 07, 2010 1:52 pm
Sorry, try this:
date >= @dateval("2006:01", "yyyy:mm") and date <= @dateval("2009:04", "yyyy:mm")
