Finding the root of a univariate function
Fifis
Postby Fifis » Tue Nov 22, 2022 6:50 am
Dear all,
Sorry if it is a duplicate; I posted a similar question to the 'Programming' section, but realised that root finding is a form of estimation. Does EViews have root-finding capabilities for a univariate function (Brent's method, bisecetion, secant, or something similar)?
Simple example: there are monthly data for the levels of some indicator. There are forecast monthly logarithmic growth rates (pre-defined). There is a forecast annual figure for the total monthly sales (i.e. their sum). The goal is to find such a constant that, when added to all monthly growth rates, would produce a series of levels that add up to the annual figure. This is the quick working example in R:
r <- c(-0.063, 0.018, -0.084, 0.160, 0.033, -0.082, 0.049, 0.074, 0.058, -0.031, 0.151, 0.039) y.ann.sum.desired <- 15 y <- exp(cumsum(r)) # Levels from log-growth rates y.ann.sum <- sum(y) # 13.02 -- lower than the desired 15
One can manually fiddle with the values and arrive at an approximate answer.
sumCorr <- function(x = 0) sum(exp(cumsum(r + x))) sumCorr(0.01) # = 13.96, closer to the truth sumCorr(x = 0.0201) # = 15.0007, overshoot sumCorr(x = 0.020093) # = 14.9999, almost correct
However, there is an immensely helpful function in many packages -- a univariate root solver to find the root of the equation `f(x) = 0` -- in our case, `sum(exp(cumsum(r + x))) - 15 = 0`:
uniroot(function(x) sumCorr(x) - y.ann.sum.desired, interval = c(0.01, 0.03), tol = 1e-10) # $root = 0.02009369 sum(exp(cumsum(r + 0.0200936879))) # 15.000000005, great!
I need to implement multiple such corrections in multiple projects in EViews, and am asking what the good way to start would be. (This is a simplified example, which is why analytical solution won't cut it -- the real expressions do not have closed-form solutions.) Any ideas about how to avoid hard-coding the bisection routines and rely on the built-in EViews capabilities?
Many thanks in advance!
Yours sincerly,
Andreï V. Kostyrka
EViews Matt
Re: Finding the root of a univariate function
Postby EViews Matt » Tue Nov 22, 2022 11:12 am
You can use EViews' user-defined optimization feature for this purpose. I've recreated your example as an EViews program below.
wfcreate u 12 series r r.fill -0.063, 0.018, -0.084, 0.160, 0.033, -0.082, 0.049, 0.074, 0.058, -0.031, 0.151, 0.039 subroutine local objectiveFunction(scalar !objective, scalar !x, series r, scalar !target) series tmp = @exp(@cumsum(r + !x)) !objective = @pow(@sum(tmp) - !target, 2) endsub !objective = 0 scalar x = 0 optimize(min) objectiveFunction(!objective, x, r, 15)
Fifis
Postby Fifis » Mon Nov 28, 2022 1:39 am
Many thanks! This is what I was looking for.
