Saving tables as images Eviews 13, graphics issue
Posted: Thu Nov 03, 2022 4:30 am
by ErikG
When saving an Eviews table as emf/png/ or similar I am getting a white area in the upper right hand corner that is not present in the table in the Eviews workfile. This was not the case prior to my Eviews 13 update.
I simplified my code as an example for you:
WfCreate(page=a) C:\temp\temp.wf1 a 2007 2010 Series year = 1999 Series vX = 3 Series vY = 4 Series vZ = 5 Group g1 Year vx vy vz Stomna(g1, m1) m1 = @Transpose(m1) Freeze(t1) m1.table Call FormatlandscapeTable(t1) t1(1,1) = "Title" t1(2,1) = "Percent" t1(3,1) = "X" t1(4,1) = "Y" t1(5,1) = "Z" t1.save(t=emf, n="-") C:\temp\Test Subroutine FormatLandscapeTable(Table TAB) tab.deleterow(1) 2 !kr = tab.@rows !kc = tab.@cols tab.setformat(2) f.0 tab.setformat(3:!kr) f.1 tab.insertrow(!kr+1) 2 tab(!kr+2,1) = "Date and time" tab.setlines(@All) -a For !i = 3 To !kr Step 2 tab.setfillcolor(!i) @rgb(196, 226, 255) Next For !i = 1 To 2 tab.setfillcolor(!i) @rgb(54, 100, 139) tab.settextcolor(!i) White Next tab.setfillcolor(!kr+2) White EndSub Shell C:\temp\Test.emf
Enterprise edition october 11 build
Re: Saving tables as images Eviews 13, graphics issue
Posted: Thu Nov 03, 2022 12:47 pm
by EViews Jason
In the spreadsheet views of matrices, groups, and series, EViews places just below the column labels meta information about the object. This normally includes any history information (i.e. 'last updated') and remarks. The rows that contain this information, has special row centering formatting. When saving tables to file which have this formatting, preserving the onscreen appearance is not trivial.
In your program, you removed one of the rows which has this formatting and left the line after to modify. The first line of subroutine FormatLandscapeTable reads
tab.deleterow(1) 2
This removes the column labels and the history information. The line after the history information is blank but has the row centering formatting. I suggest also removing that line and then inserting a new blank which will not have the centering formatting.
tab.deleterow(1) 3 tab.insertrow(1) 1
The resultant emf should now appear as expected.
Note: the issue also appears in versions prior to 13 as well.
Posted: Fri Nov 04, 2022 6:56 am
by ErikG
Excellent, thanks!
