Clipboard Copy of Actual-Fitted-Residual graph becomes pale in EViews13
watabehj
Postby watabehj » Tue Oct 11, 2022 1:04 am
Hello. I am using EViews13 (Standard Edition Oct 4 Build). When I copy Actual-Fitted-Residual graph of Equation object to Excel, lines are very pale compared to EViews12 or earlier. Attached please find Excel file which I copied Actual-Fitted-Residual graph of eq3 in basics.wf1 (chapter20 example file) using EViews 13 and 12.
equationgraph.xlsx
(64.68 KiB) Downloaded 758 times
Re: Clipboard Copy of Actual-Fitted-Residual graph becomes pale in EViews13
Postby EViews Jason » Tue Oct 11, 2022 9:58 am
Try turning off opacity for the all the lines in the graph.
Double click the graph to open the graph dialog.
Next select Graph Elements->Lines & symbols.
Select all of the lines in the box on the right
Change the Opacity setting to Off (located on the bottom right of the dialog)
watabehj
Postby watabehj » Tue Oct 11, 2022 5:12 pm
Thank you. I see I can use [Options]-[Graphics Defaults] to permanently change the setting.
