mixed graph: removing text not possible
mamo
Postby mamo » Tue Jun 21, 2022 7:20 am
Dear Eviews team,
I use Eviews 12 March 2021 built
Removing an arbitrary piece of text which has been added to a mixed graph is not possible, Trying to do so gives an error message.
Run the example program below and try to manually remove the text "test" from the graph "gra". This gives an the error message "Removing series from mixed graphs is not allowed". You may also try with manually inserted pieces of text. The error message pops up as soon as one tries to remove some text from the graph. It does not matter whether the text has been inserted manually or via the .addtext procedure.
Would be nice if this bug could be fixed in an upcoming version of EVIEWS
Best, mamo
wfcreate a 2000 2010 2 series x=@crossid+nrnd series y=x-@crossid series z=@crossid group gr x y z smpl @all if @crossid=1 freeze(mode=overwrite, gra) gr.mixed(panel=i) line(1) stackedbar(2,3) gra.addtext(-0.1, -0.3) "test" show gra ' now try to remove manually the text "test"
Re: mixed graph: removing text not possible
Postby EViews Jason » Tue Jun 21, 2022 3:43 pm
mamo
Postby mamo » Wed Jun 22, 2022 1:30 am
Many thanks! For the meantime, here the work-around I found: rather than removing the text object, just empty the text in the text box. This makes the text object to disappear altogether from the graph.
Best, mamo
