frrezeing a view of an object generated by an add in in the object's own window
Posted: Wed May 25, 2022 3:35 am
Dear Eviews team,
I use Eviews 12 March 21 build.
I noticed that a view generated by an addin cannot be "frozen" using the freeze command. To explain the issue in simple ways, consider, for instance, an add-in named "myline.org" containing only one line,
and which would be registered as an add-In for series. Then, the following code should be expected to generate line-graph of x named "graph1" but it doesn't:
It would be great if this approach would become feasible in future versions of Eviews
Kind regards,
mamo
_this.line
wfcreate a 2000 2010
series x=nrnd
freeze(graph1) x.myline
Kind regards,
mamo
