ExpSmooth (Exponential Smoothing - requires R)
Posted: Mon Apr 05, 2010 1:36 pm
This thread is about the
ExpSmooth Add-in that Performs an expanded set of exponential smoothing and forecasting techniques, including automatic model selection. Note R is required for this add-in.
Change Log
- 2010/03/24 - Initial release
- 2010/04/09 - Fix for bug caused by the global option setting for sending variables over to R
Re: ExpSmooth (Exponential Smoothing - requires R)
Posted: Fri Apr 09, 2010 2:31 pm
New update posted, fixing an issue where users who had changed their global options to send over series to R in Upper Case would have problems.
Posted: Tue Sep 28, 2010 4:01 am
by Stefano
Hi all!!
I am trying to use ExpSmooth Add-in, I installed both R and the Forecast package but now when I am trying to run the add-in from the time-series object in Eviews 7 I get an error message like "R is not installed". Could you please help me to solve this problem?
Thank you in advance
Posted: Tue Sep 28, 2010 8:06 am
Do you have the statconnDCOM package installed? (See the EViews Command Reference, Chapter 7, for more details).
Posted: Tue Sep 28, 2010 8:36 am
by Stefano
Thank you Gareth,
I didn't know I need to install it...I will immediately do it
Regards
Posted: Thu Dec 02, 2010 12:54 am
by basher
I installed R, installed statconnDCOM, intalled also Scilab 5.2. After installing "rscproxy", when I verify the installation by clicking "Server 01 - Basic test", I receive the following message:
Loading StatConnector Server... Done
Initializing R...Function call failed
Code: -2147221485
Text: installation problem: unable to load connector
Releasing StatConnector Server...Done
May be I should ask this question to "R", thought I might get better response from this platform. Thank you.
Posted: Thu Dec 02, 2010 8:27 am
by EViews Steve
Hi basher:
My guess is that some of your components are not compatible with each other. Instead of installing each item separately, I would use the installer that installs everything for you in one go.
If you go to this page:
http://rcom.univie.ac.at/download.html
You can download a file called "RAndFriendsSetup2120V3.1-11-1.exe". I believe this will install everything with known compatible versions to get the statconnDCOM working. (You probably have to uninstall everything else first).
Posted: Thu Dec 02, 2010 10:11 am
by basher
Thank you Steve. It is working well.
Posted: Thu Dec 02, 2010 10:23 am
by basher
While the "expsmooth@ add-in allows to get estimates from 15 different models, I was wondering whether it is possible to integrate the state space innovations (within Eviews) in a future update of this very helpful routine. This idea is explained in the accompanying paper of the "forecast" package. Thank you.
Posted: Mon Mar 12, 2012 12:06 am
by jaekwan7337
I am currently using Exponential Smooth Transition model to test a existence of bubble. It is nonlinear model, and I read one of your comments here that this add in will be allow me to get more accurate estimate for the coefficient, as I dont know how to do grid search from eviews.
the model is as below.
DPQUK=C(1)*PQUK(-1)*(1-EXP(-C(2)*PQUK(-1)^2))+DPQUK(-1)
I have installed the add in, but the add in only works with the single series, rather than the model estimation.
Can you give me some advice?
cheers,
Jake
Posted: Mon Mar 12, 2012 12:47 am
by trubador
That is because it falls into the category of "smooth transition" models, which is a very different concept than smoothing. Following discussion will be helpful:
http://forums.eviews.com/viewtopic.php?f=4&t=3712
