Page 1 of 2
2sls with 2 simultaneous equations
Posted: Sun Apr 03, 2022 2:16 am
by AgentRose
Say I got 2 equations:
(1) Y1 = Alpha + Y2 + AX1 + BX2 + CX3 + E
(2) Y2 = Beta + Y1 + DX4 + BX2 + FX5 + GX6 + U
How would you do the 2sls? I keep getting singular matrix error messages or insufficient instrument variables?
I have been inputting equation 1 as model specification and X1, X2, X3, X4, X5, and X6 as the instruments, but keep getting error messages so I tried different things but still keep receiving errors or really unsure of the answers.
Re: 2sls with 2 simultaneous equations
Posted: Sun Apr 03, 2022 7:07 am
Show us the commands you use and maybe attach the EViews workfile.
Posted: Sun Apr 03, 2022 7:31 am
by AgentRose
Quick, Estimate Equation, 2sls
Equation specification: Y1 c Y2 + AX1 + BX2 + CX3 + E
Instruments: AXI BX2 CX3 DX4 FX5 GX6
I think I got near a singular matrix for this one. How are you meant to do 2sls when you got 2 simultaneous equations with 2 endogenous variables and 6 exogenous variables? The variable X2 get repeated in both equations, and the seconds' equation have more variables.
Posted: Sun Apr 03, 2022 7:33 am
by AgentRose
Equation specification: Y1 c Y2 X1 X2 X3 + E
Instruments: XI X2 X3 X4 X5 X6
Posted: Sun Apr 03, 2022 7:35 am
by AgentRose
How do you let Eviews know which variables are endogenous and which variables are exogenous in tsls, and the variables that form the 2 equations?
Posted: Sun Apr 03, 2022 7:37 am
Is the variable named X2 or BX2? When using EViews this way you don't need to include coefficient names or the error term or + signs.
Posted: Sun Apr 03, 2022 11:32 am
by AgentRose
Equation specification: Y1 c Y2 + X1 + X2 + X3 + E
I think I got near a singular matrix for this one. How are you meant to do 2sls when you got 2 simultaneous equations with 2 endogenous variables and 6 exogenous variables? The variable X2 get repeated in both equations, and the seconds' equation has more variables.
I didn't put any signs, coefficient or error terms when inputting the variables on the Eviews screen
Posted: Sun Apr 03, 2022 11:35 am
by AgentRose
How would you do it when there is an unequal number of variables in the two equations. I am sure the equation is over-identified so 2sls should work right, or at least produce some results from half the equation?
Posted: Sun Apr 03, 2022 11:42 am
That looks correct. So it's probably a problem with your data.
Posted: Sun Apr 03, 2022 4:46 pm
by AgentRose
Could it not be something to do with the second equation having 1 additional variable compared to equation 1 or that the variable X2 exists in both equations?
Posted: Sun Apr 03, 2022 5:13 pm
Nope. The former means that the first equation is overidentified and the latter means that X2 is exogenous and serving as its own instrument. Both are fine for 2sls.
Posted: Mon Apr 04, 2022 3:04 am
by AgentRose
You were right! THANK YOU so MUCH!!
Posted: Mon Apr 04, 2022 3:18 am
by AgentRose
For the first stage of the equations would you just input LS of the structural equation for equations 1 and 2 to get the F-stat or would you input the reduced form equation to get the F-stat?
Posted: Mon Apr 04, 2022 6:11 am
For the first-stage F you want the reduced form.
Posted: Mon Apr 04, 2022 5:20 pm
by AgentRose
Wouldn't you get the same generalised equation but like different letters instead?
How would you do it with so many variables? What difference does it make? Cause I did get an answer but I think I did it the structural formula way and get a low F-stat. Can you just straight up put equation 2 in the brackets with the rest of equation 1 and not simplify the equation further on Eviews?
