Code from oldes Eviews version to run into the newest eviews version 12.0
jcgrass
Postby jcgrass » Fri Sep 10, 2021 12:31 pm
I tried to run this code taken from this expectacular blog of programmers (supuse used to make roc curve) but i can´t, seems to be is belongs to oldes eviews version. So it's possible to run in to the newest eviews version 12.0. What step do i have to do? Thanks
Juan Carlos Grass Galvis
%dep = "grade" %eq = "eq_probit" ' find valid observations {%eq}.makeresid _xxe ' get number of 0 and 1 smpl if _xxe<>na and {%dep} = 0 !n0 = @obs({%dep}) smpl if _xxe<>na and {%dep} = 1 !n1 = @obs({%dep}) ' get fittted values smpl if _xxe<>na {%eq}.forecast _xxyf group a {%dep} _xxyf stom(a, b) stom(_xxyf, _xxprob) ' sort in descending order so we have threshold of infinity which is "off" vector _xxpranks = @ranks(_xxprob, "d", "i") matrix _xxsdata = @capplyranks(b, _xxpranks) ' get unique fitted values vector _xxuniq = @uniquevals(pranks) !nunique = @rows(_xxuniq) delete _xxuniq ' create output ROC matrix matrix(!nunique+2, 4) _xxroc ' we start at threshold of infinity which is "off" !ntype1 = 0 ' number of correct 1 predictions !ntype0 = !n0 ' number of correct 0 predictions !j = 1 !i = 1 !n = @rows(_xxsdata) roc(1, 1) = 1 - (!ntype0 / !n0) ' 1 - specificity roc(1, 2) = !ntype1 / !n1 ' sensitivity roc(1, 3) = 0 roc(1, 4) = 0 while !j <= !nunique !target = _xxsdata(!i, 2) !val = !target while !val = !target !response = sdata(!i, 1) if (!response = 0) then !ntype0 = !ntype0 - 1 endif if (!response = 1) then !ntype1 = !ntype1 + 1 endif !i = !i+1 if (!i > !n) then !val = 0 else !val = sdata(!i, 2) endif wend _xxroc(!j+1, 1) = 1 - (!ntype0 / !n0) _xxroc(!j+1, 2) = !ntype1 / !n1 _xxroc(!j+1, 3) = !j / !nunique _xxroc(!j+1, 4) = !j / !nunique !j = !j + 1 wend _xxroc(!j+1, 1) = 1 - (!ntype0 / !n0) _xxroc(!j+1, 2) = !ntype1 / !n1 delete(noerr) roc_graph freeze(roc_graph) _xxroc.xypair roc_graph.options linepat -legend size(4,4) roc_graph.setelem(1) linewidth(1.15) roc_graph.setelem(2) linepattern(8) %title = "ROC graph for" %title = %title + " " + @upper(%eq) roc_graph.addtext(t, font("Ariel", 12)) %title roc_graph.addtext(l) "True Positive Rate" roc_graph.addtext(b) "False Positive Rate" show roc_graph delete _xx*
Re: Code from oldes Eviews version to run into the newest eviews version 12.0
Postby EViews Gareth » Fri Sep 10, 2021 1:34 pm
Seems like it would work in EV12
