Verbose syntax/comment program for rolling panel regression
AbnormalDistribution
Postby AbnormalDistribution » Mon Aug 30, 2021 10:24 pm
After reviewing the forum discussions on this topic, such as:
http://forums.eviews.com/viewtopic.php? ... ion#p65681
I noticed there has been consistent and even growing interest in rolling panel regression functionality.
However, it would appear that EViews doesn't offer a native function for panel rolling regressions, but one could attempt a program as is discussed here:
http://forums.eviews.com/viewtopic.php?t=18592
However, in many of such threads, the complete rolling regression program hasn't been provided for the panel case.
I was hoping that we could adapt the basic rolling regression EViews Gareth begun:
http://forums.eviews.com/viewtopic.php?f=15&t=878
To mold it into a panel rolling regression, it might be nice to have comments to denote what would change based on cross section and periods included
Purely as an example, in my case:
  • Periods:53
  • Cross sections: 670
  • Total (unblanced) observations: 21558
I tried the following code with the equation.ls(cx=f) as suggested:
'Configuration %y = "y" %const = c %var1 = "x1" %var2 = "x2" %var3 = "x3" %var4 = "x4" %var5 = "x5" %var6 = "x6" %var7 = "x7" '------------------------------------------------------------------------------------- 'run rolling regression ' set window size !window = 21558 ' set step size !step = 3000 ' get size of workfile !length = @obsrange ' declare equation for estimation equation eq1 'calculate number of rolls !nrolls = @round((!length-!window)/!step) 'matrix to store coefficient estimates matrix(8,!nrolls) coefmat ' where 8 is the number of coefficients 'variable keeping track of how many rolls we've done !j=0 ' move sample !step obs at a time for !i = 1 to !length-!window+1-!step step !step !j=!j+1 ' set sample to estimation period smpl @first+!i-1 @first+!i+!window-2 ' estimate equation - where the equation is y=c(1) + c(2)*x1 + c(3)*x2 eq1.ls(cx=f) {%y} {%const} {%x1} {%x2} {%x3} {%x4} {%x5} {%x6} {%x7} 'store coefficients colplace(coefmat,eq1.@coefs,!j) next show coefmat
However, this just gave me a 8x3 matrix. I was expecting 8x50-ish, to cover most of the periods observed. At least for me, it's difficult to figure out how to tweak the syntax to output betas across my desired time horizon.
Re: Verbose syntax/comment program for rolling panel regression
Postby EViews Gareth » Tue Aug 31, 2021 8:52 am
Without thinking about it too much, really the only thing that needs to change in a panel case is the calculation of the number of rolls. Might be easier for you to just calculate it by hand and hard code it.
